355 tpi build
Old Mar 27, 2012 | 08:35 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
355 tpi build
Ok so I decided I'm using my 355 as a tpi it is carb now but I'm switching over in the motor I have summit racing timing gears (nose makers), I have pre 86 194 intake cast iron heads on it at the moment an plan on using these with the tpi setup I do have a pre 86 tpi intake I should be able to use this on the 355 what else would I have to swap over in order to use the stock 350 spun a rod bearing so that's why Im switching over to my 355 instead of rebuilding The stock l98
Old Mar 27, 2012 | 10:17 PM
Engine: LR4 4.8
Re: 355 tpi build
53 views an no replys come on people Help me out here
Old Mar 28, 2012 | 01:56 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: 355 tpi build
It's hard to find the question in there .
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 13, 2015 07:35 AM
Sanjay
Aug 12, 2015 03:41 PM
