cold air intake kit
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: cold air intake kit
Assuming you are talking about a firebird since you have KITT in your sig. A cold air intake is tough on a firebird because of the hidden headlights. Not sure if there is an aftermarket CAI available, but even if there was I don't know where you would put it. I saw a pic of one once, but it only took in hot underhood air. Comparitively, the stock air filter isn't that bad, because at least the intake is aimed at a cold air source (behind the right headlight). The stock Camaro TPI actually takes in cold air from in front of the rad.
Engine: 4++,350 & 305 CIs
Try and find a used SLP cold air kit for your bird.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
