1986 trans am tpi problems
Old Apr 4, 2012 | 03:36 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
My wife has a 86 trans am 305 tpi its running like crap even at idle i put new plugs wires cap rotor coil pvc.So i took the plugs out today all of them and they all have black carbon and wet and smell like fuel. What could it be i have been told a lot of thing like the mass airflow snsor or the dizzy fuel reg cold start injector there is no check engine light expect when you just turn the key on. I really need help to get this fixed in new to the tpi forms i have a 92 firebird tbi 305 and i dont have any problems like that my car runs perfect my wifes car is a 86 tpi auto with 3.27 posi rearend
Old Apr 4, 2012 | 06:08 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: 1986 trans am tpi problems
I bet your injectors are leaking. How long does the fuel rail hold fuel pressure after the engine is stopped? Measure the ohms for each injector, they should all be around 16 (0 indicates a short in the injector).
Hope this helps.
Old Apr 4, 2012 | 06:47 PM
thanks ill check on that
84z96L31vortec
Aug 20, 2017 12:16 AM
beachrodder
Aug 25, 2015 08:05 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
