Supercharging 87 irocz
Old Apr 7, 2012 | 02:17 AM
twest2k2's Avatar
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
I am looking at getting a procharger for my 87 350ci tpi. This car has the v belt system with an qc delete and smog delete. Can somebody please give ne info or direct me to info on switching to serpentine style? I need to replace the water pump with a reverse rotating water pump right? Is it basically that simple besides getting the correct belt?
Any thoughts and/or experience would help.
BTW, how easy would the procharger kit be to tune?
Old Apr 8, 2012 | 02:02 AM
twest2k2's Avatar
Re: Supercharging 87 irocz
Bump
Old Apr 9, 2012 | 08:26 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i've done it, pull all that old crap off and replace it with a serpentine setup
Old Apr 9, 2012 | 08:57 AM
Guest
Guest
Posts: n/a
Procharger FTW!
Old Apr 9, 2012 | 01:49 PM
twest2k2's Avatar
Right on. Can't wait to get it done. Thanks for the reassurance. Can I put underdrive pulleys from an 88 on
Old Aug 26, 2012 | 07:29 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
What all is required with this swap with regards to the wiring harness since a/c & alternator are on opposite sides. Aside from I guess extending those wires, is there anything else to be done or did you switch to a different harness as well?
Luigytico09
Oct 1, 2015 08:46 AM
ASE doc
Sep 22, 2015 03:13 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IBrockZ
Aug 20, 2015 12:20 PM
