TPI swap
Old Apr 11, 2012 | 06:33 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
TPI swap
Hey guys I have a 92 Camaro with a 305 TBI, im swapping in the base GM 350 engine (I know its shitty but I bought it knowing it will be a money pit) and I want to do a TPI swap. What parts do I need, and what modifications do I need to do, or is there a kit to buy? thanks, and I'm sorry if there is already a thread but I could not find it. thanks alot
Old Apr 12, 2012 | 06:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI swap
Always check the " stickies" at the top of a page
https://www.thirdgen.org/forums/tpi/...d-density.html
You need a TPI intake complete <$250 and a '730 ECM ( computer) >$75
Time to hit CL , the junkyard or look at the 3rd Gen for sale.
TPI parts always for sale there
https://www.thirdgen.org/forums/engi...pension-parts/
Old Apr 12, 2012 | 07:23 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Re: TPI swap
i just did the same swap.
wire harness & ecm from a Speed Density car
dual fans
find connector 207 behind the p/s glove box area and the VSS buffer box in the same area. Take the tan and brown wire going into the buffer box and connect them. throw the buffer box out. then at the connector 207 there is 1 wire that needs to be moved. i think its the brown wire on the black side of the connector to the grey wire at the clear side...
thats pretty much it
otherwise plug n play
Old Apr 12, 2012 | 09:19 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: TPI swap
do a search for tbi tpi conversion. there are many step by step threads with pictures, and the answers your looking for.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
