Is there a cam possible.
Old Apr 23, 2012 | 10:06 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I have a 88 305 LB9 TPI, 3.73 gears, headers, exhaust. I want to put a cam in my car, it has MAF and the stock PROM. I would like a cam that i could just slide right in, use with my stock heads (60,000 miles on them), and not need a tune and see a power increase between 1000-4500 RPMs. Please dont tell me to go get my heads done or get new springs, if i need to i wont touch the cam. My timing chain cover is leaking i need to replace the seal, a little more work and i can put the cam in. To recap, I want a cam that i can use with my vehicle, without touching my heads, and without tuning the computer, stock lifters, stock rods, stock rocker arms. Any cams like this out there, if so could someone help me with the numbers, lift duration that i can look for that will fit me.
Old Apr 24, 2012 | 12:18 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Is there a cam possible.
Anyone can help ?
Old Apr 24, 2012 | 12:49 AM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
5 speed or auto?
If 5 speed the 305 cam is not bad.
also if you have the 081 heads those are good too.
The stock cam just don"t have much lift and that is why you want a roller cam anyway.
Call comp cams help line and if you need to change the spring you can do it with the engine in the car. cheers
Old Apr 24, 2012 | 05:18 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you're changing the timing cover gasket, sure, put a cam in it. You can reuse the stock roller lifters, but you should change the valve springs just due to age. I had the following cam put into a 305 during a rebuild, and I'm happy with it. It's faily mild so it idles nice:
http://www.compcams.com/Company/CC/c...?csid=211&sb=2
Old Apr 24, 2012 | 10:52 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
What are your goals with the car? Do you have to do any emissions testing? Are you going to leave the rest of the motor alone or are you going to make other changes to the car?
Old Apr 24, 2012 | 04:46 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I have NO emissions testing at all in my state for my year, my goal is to gain a little horsepower and gain some torque. My main goal is to put a cam in it with requires absolutely no computer tune.
Old Apr 24, 2012 | 04:47 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
you put it in a stock TPI without a tune, MAF ? how was the difference
Old Apr 24, 2012 | 06:41 PM
yaj15's Avatar
Car: 1988 IROC-Z
http://www.cranecams.com/88-89.pdf
This is a listing of some of the cams for the LB9 and L98 engines. The last two cams on the page would work best with some computer tuning as well.
If your car has the LB9/auto trans cam an upgrade that would require no computer changes is the stock LB9/G92/5-speed cam. This was also the cam that was installed in the L98 as well.
A lot of people are also running the ZZ4 cam.
Your car will run fine with a mild cam shaft that does not have too many variations from the stock L98 cam though. Aside from using one of the stock cams for our cars, computer tuning would yield the best performance outcome for your specific combination.
Old Apr 24, 2012 | 06:49 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
The 262HR-12, requires no TPI mods and no computer tuning.
Old Apr 24, 2012 | 06:50 PM
yaj15's Avatar
Car: 1988 IROC-Z
Oh, I forgot to mention. When looking at the stock L98 & LB9/G92/5-speed cams - look at ones with the '88-'92 specs. Those have a little more intake and exhaust valve lift compaired to the '87 L98 cam. Although any of the '87 L98 and '87 LB9/G92/5-speed cams would be an upgrade over the stock LB9/automatic combination cam.
Old Apr 24, 2012 | 06:51 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
How do i change my valve springs myself with the heads in the car.
Old Apr 24, 2012 | 07:42 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Mostly stock, only changes are mild intake porting cam listed and 3" exhaust. No tuning. Car runs great, has more power and sounds better than stock. This cam is not for all out power, but it's a nice improvement. Also a 5 speed, 3.45 axle.
You can change the springs in the car. Pressurize the cylinder with air through the spark plug hole to hold the valve up, and you can compress the spring for removal. There are detailed writeups on this site on how to do this.
Old Apr 24, 2012 | 09:54 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
with this cam, my mods and the stock intake i should have some decent torq
ue numbers no?
Old Apr 29, 2012 | 08:59 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Should I take a chance on this cam http://www.ebay.com/itm/LT4-Hot-Cam-...#ht_500wt_1287
Old Apr 29, 2012 | 10:56 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
if you're gonna swap the cam do it right, you can't use the LT4 cam with stock heads either. you need bee hive springs or the heads milled for the dual spring or you will hit the retainer. The stock LT1 cam is decent and can be had for around $50. I have a 91' L98 cam sitting in my garage if you're interested.
Old Apr 30, 2012 | 05:49 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
What are the specs on your L98 and specs on the lt1? And they can both be used with stock lifters, stock springs, stock rods and all?
Old May 1, 2012 | 07:44 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
In 1988 ( i used 88 because my ECM and TPI system are from an 88) a 5speed car came stock 220 horse, this was because of the cam correct? So if i install this cam even though it isnt big it still has a little more lift than a 5speed cam and needs no tuning or other add ons. so with that cam wont i at least see that 25hp increase? please correct me if im wrong
Jorlain
Oct 8, 2015 01:57 AM
dbrochard
Oct 3, 2015 12:43 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
