Is the Holley AFPR still prone to leaking?
Old Apr 29, 2012 | 09:18 PM
Legdiian's Avatar
My 91's stock regulator is leaking out the vacuum line so I'm in the market for an AFPR. I've tried searching the forums. Seems like some people love the Holleys and some hate them. Most of the posts were from several years ago. Do they still have a tendency to tear diaphragms all the time?
If the Holleys are still prone to leaking, what's a good alternative?
Old Apr 29, 2012 | 09:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Is the Holley AFPR still prone to leaking?
if your getting fuel out the vacuum port you need a new diaphragm. Not sure what modifications you have done to your engine to need higher fuel pressure but it can over works your injectors. If you are running your stock multitech's time to upgrade to the bosch 3's from southbayfuel injectors. The bbks I have seen the the flanged out vacuum nipple leak and actually come out of the regulator top.
Old Apr 29, 2012 | 09:32 PM
Legdiian's Avatar
I have a built 383 that is going in at some point in the near future, so I figured might as well spring for the AFPR now. Or would I be better off just replacing the diaphragm in the stock regulator and doing a remote mount AFPR when the motor goes in...
Ok next question :
Best place to get a new diaphragm? Autozone sells one for like 70 bucks. I don't want to be replacing this thing in a month though. (I've had some bad luck with Autozone parts). I would rather spend the money and get the highest quality part I can.
Old Apr 29, 2012 | 09:39 PM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/TPi-Fuel-Pre...953663&vxp=mtr
Old Apr 29, 2012 | 09:40 PM
Engine: Lb9
Transmission: M20
or.....
http://www.ebay.com/itm/GM-TPi-Adjus...73665b&vxp=mtr
Old Apr 29, 2012 | 09:47 PM
Legdiian's Avatar
Originally Posted by tunedperformanc
Thanks very much
Old Apr 29, 2012 | 09:50 PM
Engine: Lb9
Transmission: M20
Tpis, was having a sale a month ago for $50 for the diaphragm and standard motor parts can be found on amazon for I believe $60.
Old Apr 29, 2012 | 09:54 PM
Engine: Lb9
Transmission: M20
you should check out the bosch 3's at south bay for the 383.
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Magman
Sep 14, 2015 01:30 AM
355tpipickup
Sep 4, 2015 05:32 PM
