camshaft help
Old May 5, 2012 | 12:47 PM
billienaj's Avatar
Car: 86 camaro
Engine: 305 tpi
camshaft help
Hello. I've always loved that lopeing idle a big camshaft gives. I've got a 350 engine I'm trying to find a cheap rebuild kit for (just need bearings and gaskets) that I have a cam for and will be switching to carb intake. in the meantime though I was thinking putting a cam in the engine that's in my 86 tpi camaro. I have a very small prom chip in it but I was wondering if there is a cam I could put in it that would give me that idle without having to change anything more than the cam itself. Also if anyone knows a good place to get a good cheap rebuild kit that would be great as well.
Old May 5, 2012 | 12:55 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
Re: camshaft help
Rockauto.com seems to be cheap. Been looking at some stuff from them but don't know if buying parts aha cheap are worth the trouble.
Old May 5, 2012 | 01:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: camshaft help
Any cam big enough to lope isn't computer compatible.
Old May 12, 2012 | 02:12 PM
billienaj's Avatar
Car: 86 camaro
Engine: 305 tpi
Re: camshaft help
Old May 19, 2012 | 01:01 PM
mike40sm2's Avatar
Car: 1986 Iroc Camaro
Engine: 350+
Re: camshaft help
I have a tpi fitted with a 350 pontiac engine the summit cam was fitted by someone else but cant i cant get it to run could your answer above be the problem????
I have fitted this camshaft below but having some issues with running right which I'm not sure yet if its the cam causing the problem or not???
Howards Cams 180245-10 - Howards Cams Hydraulic Roller Camshafts
Camshaft, Marine, Hydraulic Roller Tappet, Advertised Duration 278/284, Lift .500/.510, Chevy, 5.0, 5.7L, Each
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
