Lining up Serpentine Pulleys
Old May 14, 2012 | 01:46 AM
algershick's Avatar
The engine in my car is NOT the original 305. The previous owner claims that the engine is a 350 which I haven't been able to confirm at this point. The numbers off of the passenger side pad of the block are machined off. The heads, however, have a casting number for a late 60's/ early 70's 350.
The TPI accessory drive brackets have been reinstalled. The balancer pulley does not line up with the rest of the brackets, so my question is are TPI engine balancers a different thickness than other small block balancers? Or is it possible that they have installed an incorrect serpentine pulley?
Old May 15, 2012 | 08:16 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Lining up Serpentine Pulleys
Lots of possibilities. Could be the wrong pulley or perhaps the balancer is not seated fully?
Old May 17, 2012 | 09:09 PM
amargari's Avatar
Car: 73 Camaro LT/RS
Engine: 327
Transmission: Supert T-10
Balancer should not be the issue unless it isn't installed all the way. You could have unmatched pulleys. Not all serpentine systems use the same pulleys. I have part numbers and information about serpentine systems at the following link. http://www.apiem.com/camaro/tpiserpentine20110306.asp
Old May 18, 2012 | 03:03 AM
algershick's Avatar
Thanks for the information. I'll try to take my pulley off tomorrow and see if I can find a part number. The thing is, my crank pulley sticks out further than the rest of the system, and according to that article TBI crank pulleys were not as tall as TPI. So assuming the balancer is installed correctly, I have a pulley that's taller than a TPI pulley.
Old Sep 14, 2012 | 02:02 PM
algershick's Avatar
I am back to work on this motor in my GTA. I've got a casting number of 10054727 on the rear of the block, identifying it as an 86-up 350.
I have torqued the balancer but the pulley still sticks out too far, about 1/4" further than the rest of my pulleys. The balancer pulley is the correct TPI part number 10055879.
My harmonic balancer is 1 11/16" thick. Can anybody chime in with the thickness of their 350 balancer? It looks like mine is seated properly..
Edit: I'm going to pick up a balancer install tool and make sure its all the way seated before I worry too much about anything else.
Old Sep 14, 2012 | 03:27 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Can you get an inspection mirror and look behind the balancer? You might be able to tell by looking at the snout of the balancer and its relationship to the timing cover seal if it's fully seated or not.
Old Sep 14, 2012 | 05:01 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
This could help to tell you because you would see the shiny area that was past the seal sticking out.
The Harmonic Balancer must be installed with an installation tool because it will not seat just by torqueing it with the center bolt.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
BDR
Nov 7, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
