What IAC to use.... Need advice!!!
Old May 22, 2012 | 09:02 AM
DBRjeep350TPI's Avatar
I know that someone out has got to know the difference between the IAC for the different years…
I think I may need a new IAC but not sure what one I need. I have a 87’ TPI unit and TB for that year, but converted to a speed density utilizing the 1227730 ECU. This is my question and I cant see to get a solid answer.
On 85-88 IROC they used they used an IAC (Standard part number AC-1) and on the 89-92 they use IAC (Standard part number AC-16). The cost between the two IAC is about 60 bucks. But more importantly I am not sure what one I should be using for my converted system.
I am thinking that I need the AC-16 for the speed density system for the computer to read the signal correctly… then again I am thinking that I need the AC-1 for the pinnacle to extend/contract the distances needed for the IAC housing.
Any help or guidance would be much appreciated.
Old May 22, 2012 | 10:30 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: What IAC to use.... Need advice!!!
I am also dealing with this, I bought a '87 IAC for a '87 system and it didn't work, bought one for the '90-'92 and it worked fine.
Old May 22, 2012 | 10:38 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
There was a second post on this !
https://www.thirdgen.org/forums/tpi/...t-iac-use.html
jaridjohn
Oct 5, 2015 07:01 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
