305 TPI running rough
Old May 28, 2012 | 08:07 PM
Natzilla08's Avatar
I got a 92 trans am 305 tpi, and well basically it started running bad out of nowhere. No vac leaks from what i can see. it had a tune up less than 10k ago. when running it barley make it to 1500 rpm with out stalling. you have to feather the gas just to get it there. So i decided to pull the injector wires. and well when the #7 is pulled it ran better.. it would rev all the way with out much problem. but as soon as i plug it back in it runs like crap again? any suggestions?
Old May 28, 2012 | 08:31 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: 305 TPI running rough
check the ohms on all of the injectors with a volt meter
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
