58MM TB BELLOWS
Old May 31, 2012 | 09:21 AM
gshell's Avatar
Car: 87 IROC
Engine: 383, stock heads, P&P edel. intk
Axle/Gears: 3.73 10 bolt
58MM TB BELLOWS
Can anyone tell me what bellow they've used when changing their stock TB to a Holley 58MM TB? My stock one doesn't seem to fit and I can't find anything on the net about it. I can't be the only one with this problem?
Old May 31, 2012 | 09:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 58MM TB BELLOWS
58mm TB should be 4". A round 4" coupler should oval out enough to fit, however my stock Camaro intake fit my 58mm holley just fine? Granted it was tight and I had to stretch a bit but it went on.
Old Jun 1, 2012 | 12:18 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Re: 58MM TB BELLOWS
My stock part fit too on my 58mm Holley TB... There was a little playing, it was tight, but it fit.
Old Jun 3, 2012 | 12:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 58MM TB BELLOWS
Yup, its very tight, use a dab of oil on the T-body so it'll slide on easier. Also make sure the clamp is super loose..
Old Jun 5, 2012 | 08:39 AM
gshell's Avatar
Car: 87 IROC
Re: 58MM TB BELLOWS
Just sent TB out to be polished. I'll try it again in a couple weeks when I get it back. Thanks for the info.
Linson
Oct 24, 2025 02:00 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCNParts
Sep 24, 2015 10:50 AM
Thornburg
Aug 27, 2015 08:33 PM
squiggy2
Aug 9, 2015 09:30 PM
