Major Problems
Old Jun 1, 2012 | 10:31 PM
Rightrightright's Avatar
Major Problems
This is my first time posting in here, so I hope you guys can help me out. I am a avid reader of these forums and this site has helped me out a lot. I'm kinda hoping posting here will solve this one. So here we go.
89 Camaro Iroc 5.7 with no Mods. Several items have been replaced over time with regular maintenance but the most recent is listed here.
I have been running the car with a slight miss and no power on the top end. Plugs, Wires, Cap and Rotor, Ignition Control Module, and Coil. No luck on fixing the issue.
While running the car I started to hear a tick. So next I ran the valves. Double check them even. (Now I will say that I have neglected this car a bit so of course all of this has been slowly making the car run better) Still miss and no power on the top end though. While taking the valve covers off the car I removed the Brake Booster Vacuum hose and about a pint of fuel poured out. (So lost at this point)
I ordered a new set of Injectors, Fuel Pressure , Diaphram, Oring Set, and Fuel Filter. Today while I was going to park my car to work on it my starter decided to die out on me. I open the engine compartment to find fuel pouring out of my Throttle Body and MAF Sensor.
Now, this is what I need to know.
What should I be looking for to fix this "Miss" and what else I should be looking to replace to fix the over all problem?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
