1.6 ratio rocker arms.
Old Jun 12, 2012 | 06:59 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
A while ago I read an article (I think it was Chevy High Performance) where they featured a '92 Z28 with the LB9/700r4/2.73 gear posi combination.
They did some minor mods to the car to try and increase the performance. One of the things that they did was install some 1.6 ratio rocker arms. At the time they didn't know that since the car had the LB9/700r4 combo that it had the small factory cam, not the cam that the '92 G92 cars got.
They did a 3 angle valve job on the heads (stayed with the stock sized valves), installed a TPIS chip, throttle body airfoil, 3.73 gear alburn posi, headers, high flow cat, and cat back exhaust if I remember correctly. Other than that the car was stock.
Is there any real performance gain by installing 1.6 rocker arms in a stock engine?
http://www.summitracing.com/parts/CCA-1418-16/
Old Jun 12, 2012 | 08:49 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: 1.6 ratio rocker arms.
On a dyno they will give you about 5hp to 10 hp and they add about .30 to your cam lift. I just added a set to my LB9 305 peanut cam 88 IROC in an attempt to get some extra hp out of this pig slow motor.
Honestly, do not expect any et in the 1/4 mile by themself alone. It takes about 15 to 20 hp to move a tenth or two in the quarter mile. However, they are a good cumulative modification that may help out your other mods.
After I installed mine it was very noticeable that my motor tached up in the rpm's alot faster and I gained about 100 rpm in the top end. But I also went full roller. I have not gone to the track yet to see if there was any et improvement but I am not really expecting any.
You can go full roller for a little bit more: http://www.summitracing.com/parts/SCC-SCP1036BL/
Old Jun 12, 2012 | 10:59 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks for the information. Yeah I have always been curious about that. It just sounded like a lot of work for a small gain in performance. I was thinking about installing a set in my car. Other than full exhaust the engine is all stock.
I just wish all the LB9/700r4 cars after '85 had the G92 style cam. I am sure they made more TPI/700r4 combinations than L98/700r4 or LB9/5-speed combinations. I guess it was to meet the fuel economy standards.
Old Jun 13, 2012 | 12:00 AM
burnout88's Avatar
Car: 88 IROC
Actually, the install is easy. One of the guys on the board came over to my place and we did the install in about an hour. One of the easier mods to install compared to most.
Old Jul 3, 2012 | 06:30 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
where can you find NON roller 1.6 rocker arms
Old Jul 4, 2012 | 03:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Self aligning or NON self aligning style rockers?
http://www.summitracing.com/search/P...eyword=rockers
Old Jul 4, 2012 | 12:21 PM
nickyakker's Avatar
well whichever rockers are on my 82 305... self aligning i guess???
Old Jul 5, 2012 | 01:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I would say bad guess given SA rockers started in '87
Might pay to check type before ordering to avoid having to exchange them
Old Jul 5, 2012 | 12:19 PM
nickyakker's Avatar
what does self aligning mean? that the rocker isnt guided strait by the push rod?
Old Jul 5, 2012 | 09:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Rocker has " ears' that center the rocker on the valve stem so it is " self aligning " and is not relying on the pushrod
Old Aug 8, 2012 | 01:48 AM
nickynick17's Avatar
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
If I put 1.6 roller rocker in my stock L98 would I need to change anything else for this mod?
Old Aug 8, 2012 | 02:42 AM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Nope, you would really just be opening the valves to allow more air in and out. So it wouldn't hurt to have headers.
Old Aug 8, 2012 | 02:52 AM
Engine: 350 TPI L98
Axle/Gears: 3.91
Ok sweet, I already have hooker headers and Im in the process of porting and polishing my TPI system
Old Aug 9, 2012 | 03:44 AM
Engine: 350 TPI L98
Axle/Gears: 3.91
By the way will I need to worry about the valves hitting the pistons when swapping in 1.6 full rollers on my stock L98 or is it just bolt on and go?
Old Aug 9, 2012 | 09:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Don't think piston clearance would be a problem, but retainer to guide/seal clearance is very tight on some of these engines. And on the earlier heads the pushrods may contact the bottom of the slot and cause noise and problems.
Old Aug 9, 2012 | 10:01 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
I have a set of Scorpion 1.6 ratio rockers for sale if interested (they run $222ish on summit)
Old Aug 10, 2012 | 12:41 AM
Engine: 350 TPI L98
Axle/Gears: 3.91
so your are saying that i may have a clearance issue with the seals and push rods with my heads since its a 1989 L98
Old Aug 10, 2012 | 03:22 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Running a full roller rocker will also help.
Mine are Comp Cams (CC) Pro Magnum self aligning. I also changed to CC Chrome Moly (CM) rods as well. CC recommends this.
If you're running centre bolt value covers, you'll need self aligning rockers.
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Damon
Sep 26, 2015 04:29 PM
