tps readings
Old Jun 13, 2012 | 04:05 PM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
tps readings
Hey all,
I've done a search and don't think I have gotten a definitive reading value
for my tps (sd 350).
Does the voltage change when the vehicle is running? These are the value I
need if someone knows them.
All I have seen is the values when the car is on but not started.
Even then I didn't see specific values. Need the for car at idle and wot.
Incidently, I don't have access to a multi-meter or I would go check myself.
Any help is appreciated.
Craig
Old Jun 13, 2012 | 04:09 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: tps readings
Key forward(running or not).55 volts at idle, then it works it way to 4.51v at WOT. your going to have to verify what you have using a meter or data logging software.
Old Jun 14, 2012 | 06:35 AM
Car: 1990 gta
Re: tps readings
Thanks!!!!!!!!!!!!!!!!!!
pjsparts
Oct 29, 2025 06:39 PM
J-money
Jan 4, 2019 09:45 AM
Linson
Sep 21, 2015 01:08 PM
TrevinE
Sep 14, 2015 03:20 PM
