500hp+ TPI Air intake what CFM
Old Jun 13, 2012 | 07:54 PM
IrocEspo28's Avatar
Car: 1988 Camaro
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 373
hey guys,
Bulit a 500HP+ tpi engine, need a recomdation on how to get the air in for it. Its getting and EZ EFI treatment as we speak so no more MAF (yes!!) As of now I have a RC 5000, which from what I read only flows 600cfm(hot air), or a modified tpi box that built thru instuctions on the boards but KN tpi filters from what understand only flows 550-600cfm cold. so the filter would not support the mod box? from reading I need 1000-1100cfm to support the HP. What cfm should I have ? and how do I route it? Need some help!!
Old Jun 13, 2012 | 08:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 500hp+ TPI Air intake what CFM
Very optimistic on a 383 with TPI What did it dyno at ?
Read
http://xtremecarzone.com.au/index.php?showtopic=386
As you can see from the intake comparison linked above ,the intake is the limiting factor to making power
Change the intake to something that breathes
Old Jun 13, 2012 | 08:34 PM
IrocEspo28's Avatar
Car: 1988 Camaro
Engine: 383
Axle/Gears: 373
Sorry, 388 HSR, Pocket ported and port matched iron eagle 2.02 1.60, 58mm tb, lunati vodoo , 36lbs inj
Old Jun 13, 2012 | 08:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So it is no longer TPI
Engine is just a pump ; can only move X amount of air @ Y revs
All the CFM calculators are showing a 383 flowing around 775cfm @7000 rpm ( assumes 100% VE )
http://www.carburetion.com/calc.asp
Old Jun 13, 2012 | 08:58 PM
IrocEspo28's Avatar
Car: 1988 Camaro
Engine: 383
Axle/Gears: 373
I got ya....did all the calulations, so what are some options? as of now im only getting 600cfm right? looks like I need to be 700 to 800 cfm and hopefully cold?
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
