not correct power?
Old Jun 22, 2012 | 02:29 AM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
not correct power?
hey friends, been a while since ive posted on here, but i had my engine combo (see sig) dynoed last year and im a little confused with the LACK OF POWER... :-[ it only made 205hp at the wheels and like 280tq or something...been a while since I've looked at the char.t but a 350, with a cam,headers, and HSR should be at least over 320 at the motor no? the tuning guy said he may be able to get another 20-30hp out of it after I get the driveshaftb balanced ut regardless that still seems low. i have a 700r4 with a shift kit and no stall converter....should i look at getting one? not sure what it really does also thinking about a t56 swap....help havent raced but it would be nice to at least be in the mid 13s when i do
cheers
Old Jun 22, 2012 | 07:31 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: not correct power?
What rear gears are you running?
Old Jun 22, 2012 | 09:02 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
under his name it says he's running 3.27. I'm curious how much more power he should have too.
Old Jun 22, 2012 | 01:43 PM
88Trans-am's Avatar
i have an apt tmrw morning to meet with the dyno guys to see what they are saying....talked to an engine machine shop amd they even said something is not right....compression toolow maybe? i think its under 9 in the 8:1 or 8.5:1...but ive never checked....new dizzy this year, fuel filter, has msd ignition.... a bit stumped really feels like it pulls hard but the number on the chart dont make me feel too good lol
Old Jun 22, 2012 | 02:02 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
What are your engine specs? If the motor/cam was built for a blower, you may not be able to take full advantage of the combo. My orig engine made 214hp/312tq at the wheels with no modifications. You should be above that for certain.
Will
Old Jun 23, 2012 | 01:29 PM
88Trans-am's Avatar
no, the motor was not built for a blower ad it is just a stock bottom end. I talked to the tuning guys today and they suggested one of their custom stand alone engine management systems as it will make things easier for them to tune...anyone else have issues with tuning the stock ecu?? they say this would be the way to go as the new system would be easier to tunr eith whatever engine modifications i do down the road.....seems other with my setup are at least 280 rwhp....mine is 207rwhp....lol quite a bit away
Glowsock
Jul 24, 2025 03:15 PM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
