Code 24 after swap
Old Jun 29, 2012 | 09:29 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
Code 24 after swap
So I took my car for a long drive today since I've worked most of the bugs out of my new motor. Got a code 24, VSS sensor code, but its got me stumped since my car never had a VSS or electronic speedometer. I swapped from an auto to a T-5 when I rebuilt the L-98 and haven't had any other issues. What could this be and is there a way to get rid of this code?
I don't have the speedometer hooked up as I've had to order the mechanical sending unit for this T-5 since it had an electronic speedo. Does a mechanical speedo still talk to the computer some how? This car has had me stumped in so many ways with all the little bugs I've had to deal with. Adjusting the TPS sensor, IAC sensor, timing, etc... trying to learn how all this stuff works.
Old Jun 30, 2012 | 08:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Code 24 after swap
You have your answer there
The computer is expecting a speed signal (VSS ) from somewhere so it knows how fast the car is going
( in your car from the speedo driven by the cable , not a VSS unit in the trans )
and it is not receiving it so you have the code up
gta90
Sep 15, 2015 04:00 PM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
