89 iroc idle and running problems
Old Jun 27, 2012 | 08:23 PM
darins89irocz's Avatar
i just bought my iroc last night and cant keep it running it feels out of time kind of missing... New cap rotor wires and plugs, put a brand new iac, and checke the pressure at the rail it was pegged at 45... Could it still be my pump cause thats about all i have left right? Besides it not running it looks sexy as hell!haha... Any thing can help guys thanks!
Old Jun 27, 2012 | 08:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 iroc idle and running problems
have you done a compression check and ohmed out your injectors ?
Old Jun 27, 2012 | 08:58 PM
no i havent... Im not to sure about timing and things like that... It now runs like the cat is clogged but doesnt smell... I just dont know.
Old Jun 27, 2012 | 09:19 PM
Old Jun 28, 2012 | 08:11 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
the first thing to do is to OHM out your injectors
Old Jun 28, 2012 | 09:27 AM
im gonna check the ohms today... How do i check the spray and if the leak? And i checked fuel pressure yesterday... What is the best upgrade for injectors?my goal is to make this car run high to mid 12s with this tpi...
Old Jun 28, 2012 | 06:48 PM
fuel injectors are fine... I believe it jumped time here is why... It is hard to start it, it feels like its just got a miss when i drive it... And it wont go over like 35mph pedal to the floor? Am i wrong? So far ive changed cap, rotor, wires plugs, iac and have checked the ohms on my injectors... All read from 17 to 19... One does run 3 thow. When i say hard to start it goes... Womp....womp... womp then fires up and idles at 500 and goes up to 600 and then bounces rpms...
Old Jun 28, 2012 | 07:12 PM
Old Jun 28, 2012 | 07:22 PM
Old Jun 30, 2012 | 08:05 PM
southbay08's Avatar
actually 19 ohm is a little on the high side. May have some issues with the coil. When you ohmed the injectors did you do it when they were cold and hot?
Old Jun 30, 2012 | 08:55 PM
Car: 91 Trans Am
Engine: 355 TPI
so check the timing, also check your firing order
Old Jun 30, 2012 | 09:23 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Check timing. Is it a MAF sensor car or MAP sensor? Check engine light on? Doubt it jumped timing.
camaro71633
Sep 1, 2015 10:24 AM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
squiggy2
Aug 9, 2015 09:30 PM
