305 tbi to tpi swap
Old Jul 3, 2012 | 08:34 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
305 tbi to tpi swap
I have a 91 rs with a 305 tbi and want to swap to a tpi system. Can I use the same harness? i heard you can repinn them to a new ecm. If so what ecm do i need? i got a tpi engine from a 87 camaro. I also have a 92 v6 parts car. I dont know if that helps me at all. thanks!
Old Jul 3, 2012 | 09:51 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 305 tbi to tpi swap
this sticky is at the top of the tpi board. Keep an eye out you'll find every answer you need on the boards.https://www.thirdgen.org/forums/tpi/...d-density.html
Old Jul 4, 2012 | 08:40 AM
08racer8's Avatar
Car: 86 iroc z 91 rs 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 posi disk brake
i did the same swap and used the v6 harness just had to change iac plug and tps plug it as real easy
Old Jul 4, 2012 | 02:49 PM
89demon's Avatar
Car: 91 RS
Axle/Gears: Posi 3.73
I did the same swap and you can repin the 91 tbi harness to run tpi very easy just changing the iac, tps,and splicing in the fuel injector connects like said,the only thing is it will become MAP but, I wanted to run MAF because, in opinion it is better and more forgiving to modifications. So it took longer for me but, it isn't that difficult at all.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
