How much hp from LT headers?
Old Jul 5, 2012 | 03:30 AM
litemupp's Avatar
Car: 88 c4
Engine: 5.7 tpi
Transmission: auto
Currently i just have an ebay CAI.
Looking to get a bit more hp out of the small 305 LB9...
How much would full exhaust including LT headers would net?
Is the HP gain worth the money?
Old Jul 7, 2012 | 01:21 AM
litemupp's Avatar
Car: 88 c4
Engine: 5.7 tpi
Transmission: auto
Re: How much hp from LT headers?
dang fellas, no replies?
I suspect at least half of members on here are running some sort of aftermarket exhaust...
Old Jul 7, 2012 | 11:42 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
if all you have for extra's on the car is a CAI, I would think about 10% hp gain.
Old Jul 8, 2012 | 12:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The ground clearance issues and installation hassles of long tubes wouldnt be worth it on a stock 305. Go with a good 3" cat-back for now, and if you really want headers, a set of shorties is fine for your power level.
Old Jul 8, 2012 | 10:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Dyno Don's headers at top down solutions are a shorty header with a custom Y-pipe. You won't find a set up with better ground clearance. I believe they are 1.75 inch primary as well. Depending on your budget, the price may be steep. I have hooker long tubes, I am apprehensive about speed bumps.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
