tpi stock injectors
Old Jul 8, 2012 | 04:09 PM
1roc89z28's Avatar
tpi stock injectors
do tpi injectors stock injectors go bad frequently? i just bought another l98. and it seems the injectors are bad, cranks alot when cold, trows white smoke on cold starts.on my other tpi cars i replaced the injectors aswell.
Old Jul 8, 2012 | 08:40 PM
laidback_81's Avatar
Car: '89 GTA
Re: tpi stock injectors
From what I've heard and read the stock multec injectors are junk. I actually just got rebuilt Bosch III's from Southbay on Friday because 3 of my stock injectors crapped out. From what I've been told is that the design of the injectors allows the fuel to seep into the coils and the alcohol/ethanol from the gas then causes the coils to erode and fail.
Old Jul 8, 2012 | 09:13 PM
southbay08's Avatar
They are junk. This biggest issue with those injectors is that they are extremely prone to coil failure...especially when they are hot. The coil is exposed in these injectors, so over time with the constant flow of fuel the coils start to fail. Unfortunately they cannot be repaired or replaced.
Steve78LT
Feb 24, 2016 12:15 AM
Brcharrelson
Aug 26, 2015 07:47 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
