What's the trick?
Old Jul 18, 2012 | 09:24 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
What's the trick?
What's the trick to getting in behind the manifold to the distributor hold down bolt. I've tried sockets(didn't fit), A bent wrench(couldn't turn it), and even a 9/16 crows foot(made a bit of progress but the head of the bolt got to a point that I couldn't get the crow's foot on it to turn it anymore). Or will I just have to fork over the cash for a GM distributor wrench?
Old Jul 18, 2012 | 10:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: What's the trick?
I just adjusted timing on a TPI an hour ago. Remove the styling cover above the distributor, unbolt the coil from it's mounts, and you can fit a 9/16 distributor wrench in there (not real easily) to loosen the hold down bolt.
Old Jul 18, 2012 | 11:47 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
They also make a "distributor wrench" that makes the whole process a breeze. They got 'em at Sears and most auto parts stores.
Old Jul 19, 2012 | 06:15 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
yeah i done mine for the first time about a month ago, had to buy one of the special dizzy wrenches, i was lucky to find one straight away here in the UK on ebay that nobody else bid on !
i also tried a socket, spanner, everything but you just cant get to the damn thing, the dizzy wrench is just enough to crack the nut off as theres still hardly any room for it to turn but it done the job
Old Jul 19, 2012 | 08:31 PM
Dakota W.'s Avatar
I've tried everything I have access to, short of taking the plenup and runners off. But I guess I'll be buying a dizzy wrench. thanks for all the info guys.
Old Jul 20, 2012 | 01:28 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
Old Jul 20, 2012 | 01:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I have the wrench pictured above and a few others in various sizes for different engines. The Snap On units are very good and they offer about every imaginable shape. I also have a 9/16" X 3/8" drive torque extender that is basically like a box end crows foot but about 2" long from center to center. It works perfectly to get into difficult distributors. I don't ever have to detach the coil either.
timonator
Sep 30, 2015 12:52 PM
RS Reaper
Sep 27, 2015 07:04 PM
Justins86bird
Sep 27, 2015 09:43 AM
92projectcamaro
Sep 24, 2015 08:09 AM
project89
Sep 22, 2015 09:35 PM
