Needing some guidance with codes
Old Jul 21, 2012 | 12:34 PM
Royal_Z's Avatar
I'm not sure if I am posting this in the correct place, if I'm not then I do apologize, but I have been doing a search and have not had any luck with the results. I am trying to figure out how I can read the codes off of my 91 Z with out using a scan tool. I've read in several threads that there is a way you can manipulate the system to flash the codes to you. Any and all help will be greatly appreciated. Thanks in advance
Old Jul 21, 2012 | 01:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Needing some guidance with codes
jumper with a paper clip the aldl pin a to b , turn the key to the accessory position and blink the codes. Fist code will be code 12 3 times then any other stored codes. To count the codes count the series of blinks code 12 is blink pause blink, blink. The aldl is under the dash driver side knee height.
http://www.chevythunder.com/fuel%20i...g%20pg%20A.htm
Old Jul 21, 2012 | 01:17 PM
Royal_Z's Avatar
Thank you thank you! Thanks a million
Old Jul 21, 2012 | 01:25 PM
Engine: Lb9
Transmission: M20
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
