BBK 58mm high idle issue
Old Jul 22, 2012 | 03:13 PM
1enick72's Avatar
I just replaced my throttle body with a 58MM BBK and I can't get my idle to drop down below 1100-1200 rpm. It seems like the air leak is from the lower front of the throttle body. If I put my finger over the hole the idle goes down and all seems good. Any ideas?
The engine is a 1989 L98 with speed density conversion, everything was fine before the change.
Is there a difference in throttle bodies between 85-88 and 89-91 other than the throttle linkage.
Old Jul 22, 2012 | 03:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: BBK 58mm high idle issue
heave you adjusted the minimum air speed by jumping the aldl and adjusting the idle speed screw ?
Old Jul 22, 2012 | 03:30 PM
1enick72's Avatar
Yes I have and have set TPS voltage with scan tool.
Old Jul 22, 2012 | 03:41 PM
Engine: Lb9
Transmission: M20
sounds like the iac is stuck if you commanded it in and set the min adjustment.
Old Jul 22, 2012 | 04:01 PM
1enick72's Avatar
I just pulled off the bottom plate to make sure the iac was seating. With the jumper in place the iac is seated but when removed it backs out a little ways.
Old Jul 22, 2012 | 04:13 PM
Engine: Lb9
Transmission: M20
did you have the iac out when you swapped it over to the new throttle body ?
Old Jul 22, 2012 | 04:38 PM
1enick72's Avatar
No, i left it in the bottom plate
Old Jul 22, 2012 | 05:19 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just curious, but is your throttle body new or used. I had a used holley that had a bad vacuum leak around the butter fly shaft, I had to buy a rebuild kit to fix the problem. Sometimes used is not so good, except for the price. Any ways, just a thought.
Old Jul 22, 2012 | 07:04 PM
1enick72's Avatar
This was a unit that had been mounted but not used. So it was not new but not used . It cam in the original box with all gaskets and mounting bolts and looked brand new.
I put my jumper in and seated the IAC and unplugged it, started it up and it idled great. Since then I have plugged the IAC back in a seems to be good, I'm not real sure why it was backing out so much. After diving I notice that the return spring setup on this throttle body is very stiff and I have a manual, is there a way to lighten this up?
Old Jul 22, 2012 | 07:54 PM
Engine: Lb9
Transmission: M20
bbk's do have a tight return spring no way to weaken the tension on it.
Old Jan 18, 2016 | 04:23 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Sorry to be the old thread resurrect-or but i'm having the same issue with the same part. Will do another iac reset. I have a scan tool that i use to put into service mode but maybe i'll try the jumper instead
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Navy8125
Aug 22, 2015 07:13 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
