Edelbrock Pro-Flo XT7137
Old Jul 29, 2012 | 05:13 PM
oramac91's Avatar
Will it fit under the hood.Has anyone bought one?If so what did you do for the fuel connections and throttle cable.Is there a tb thats good for under 350$
Old Jul 31, 2012 | 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Edelbrock Pro-Flo XT7137
I havent purchased one but from what I've seen from a vette member, its as tall if not abit shorter than the HSR and should fit under most hoods...BUT the issue is with the TB...well it may be an issue... Theres a flange that extends upward on those TB's which makes it the low clearance point.
http://forum.planetisuzoo.com/viewto...52856&start=25
Some pics down the page there of the proflo setup. HSR rubbed on my iroc hood by the TB, so anything higher at that point, it may be a concern i just dont have dimensions in front of me
Old Jul 31, 2012 | 04:04 PM
Abubaca's Avatar
I think some people have flipped the TB upside down, which fixes the "up" angle issue I believe. ....as for the intake itself, I really like the look, but have heard a lot of issues with edelbrock's quality. I think you have to be prepared to port.
EDIT....so I know I've heard people talk about flipping the TB. I think it's for the throttle cable, but...on the edelbrock, the brackets are already on the passenger side, so no need. Is the "up" angle in the manifold, or the TB itself?
Old Jul 31, 2012 | 04:17 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
From the photo in the link it looks like the raised TB flange is part of the manifold.
Old Jul 31, 2012 | 07:57 PM
oramac91's Avatar
heard a lot of issues with edelbrock's quality. I have heard nothing but good things about them. From speed shop.There 1 of the better ones.Guess i will see.
Old Jul 31, 2012 | 08:01 PM
oramac91's Avatar
with turnning the tb upsidedown.It blocks the water port hole then.
Old Jul 31, 2012 | 08:05 PM
oramac91's Avatar
Whats a good tb to buy? or use?
Old Aug 1, 2012 | 07:58 AM
Abubaca's Avatar
A lot of people don't run coolant through the TB. But if ya wanted to, then yeah, I guess it'd be a problem. It's not necessary though.
Let me clarify. Issues with with crappy casting. I can definitely see how my Eddy TPI manifold could've been nicer, although I was gonna port it anyway. You can kinda expect to port a TPI. But With the Pro-Flo/or HSR style, you shouldn't NEED to port it unless you have a specific need to do so. The HSR is clean. The Eddy is real rough.
Old Aug 1, 2012 | 04:04 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The anti-icing system that routes coolant through the TB may be necessary in cold northern climates if a car is driven during near freezing temperatures. Otherwise, since the coolest possible air charge is what the engine wants, routing coolant through the TB is counter productive.
Old Aug 1, 2012 | 07:11 PM
Abubaca's Avatar
I sometimes forget some people drive 'em everyday!
Old Aug 1, 2012 | 07:17 PM
oramac91's Avatar
Blocks the hole on the manifold.My radiator hose hooks up to it.Mine does not run thru the water pump.1 hose does but not 2
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
