30# injectors on stock pump?
Old Aug 1, 2012 | 12:58 PM
Guest
Guest
Posts: n/a
I am going to be building my engine here in about a month. Mild cam, flat top pistons, crank, exhaust, porting heads. It will be mild but should be a certifiable street killer. I am thinking of running 30# injectors on her. Can the stock fuel pump feed those?
Old Aug 1, 2012 | 01:50 PM
Blade09's Avatar
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
Re: 30# injectors on stock pump?
I'm doing the same general setup but only running 24 lb injectors. 30 might be overkill. I've been told that its alot harder to tune for oversized injectors vs smaller injectors... But then again I'm no expert lol so I'm sure someone else can explain in better detail.
Old Aug 1, 2012 | 01:56 PM
91zl98's Avatar
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
Those are some big injectors. You might want to read this article.
http://www.megamanual.com/v22manual/minj.htm
Old Aug 1, 2012 | 02:14 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Unless you're planning on making 500+ HP, I would advise against 30# injectors. Blade 09 is correct that it is much easier to increase the output of small injectors than to decrease the output of large injectors. The key is fuel pressure. The effect of pressure on injector output is linear. Injectors are generally rated at 40psi. Raising pressure to 60 psi raises output by 50%. Tuning of either the VE map or base fuel map, depending on the engine management system used, allows fine tuning of the air fuel mixture. Higher fuel pressure also improves atomization, improving combustion efficiency. The main point in choosing injector size and setting fuel pressure is to achieve injector output that allows the injector to operate within it's mechanical limits while providing the engine's fuel requirements in all operating conditions.
Running too large injectors, will leave you needing to lower fuel pressure to compensate for the too large nozzles. This will reduce efficiency and since you can't really go below 30psi on a port injected engine without affecting drivability, you are limited in how much you can tune by pressure.
Old Aug 1, 2012 | 02:32 PM
Guest
Guest
Posts: n/a
Okay I have slightly educated myself on fuel injectors now. I'll be going 24#. Can the stock pump handle those?
Old Aug 1, 2012 | 02:40 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The stock pump will be adequate to about 300HP. I would not trust it past that point, especially at higher than OE pressures. When you have invested time and money into building a motor, you don't want to risk starving it for fuel with an inadequate fuel pump. There are many choices available for upgrading the stock pump, from an in tank upgrade to a external pump. One popular choice is the Walbro high output pump. Aeromotive offers many options as well.
Old Aug 1, 2012 | 03:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have an AC Delco "stock replacement" pump in my IROC and I have absolutely no lean conditions anywhere in the RPM range with my 24lb SVO injectors at the stock fuel pressure. In fact, it ran pig rich until I dialed my injector constant way up in the BIN file. That said, I don't know whether the AC Delco replacement pump is exactly the same as the stock one or slightly more robust. My car made 250RWHP (300 crank) and my fuel pump is more than up to the task.
For the amount of effort it takes to replace a fuel pump, I'd stick with the stock one for now. If you're finding that you're lean during high fuel demand conditions, then drop your tank to replace it. That said, if you do replace it, make sure you get a good 255lb/hr Walbro or equivalent pump. It's way too much work to put in a cheap pump. If I'd known how much of a job it was prior to doing it all those years ago, I would have installed a better one!
Old Aug 1, 2012 | 05:22 PM
Guest
Guest
Posts: n/a
Awesome. Thanks for all the info
Old Aug 1, 2012 | 05:46 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Stock pump is good to around 450 hp or so. I am assuming you are keeping the TPI intake? 24 pounders will be your best bet.
Old Aug 1, 2012 | 06:35 PM
Guest
Guest
Posts: n/a
Yes the TPI is staying. For now. I see a carb in my future though
Old Aug 1, 2012 | 10:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Maybe on someone else's engine. Not mine. In my opinion, in order to assure the safe operation of a motor, a fuel system should be capable of flowing
50% more than the engine's maximum requirement at the system's actual pressure. One thing to remember is that as pressure increases, a pump's flow decreases. If you need to run 60psi, you will want a pump that at 60 psi, can flow half again what your engine requires at max power. I would never trust a factory stock TPI pump to do that. This is only my opinion, not everyone will agree with me.
Old Aug 3, 2012 | 06:35 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
I run 30#ers on mine @ 50psi and had no problems dialing it in with my custom tune. but let me stress you have to change the parameters in the prom for it to work correctly.
Old Aug 4, 2012 | 07:01 AM
Hillbill6461's Avatar
I am building a 383 with around 450 horse going to keep it tpi, will the tunercat products do the job making a chip for the ecm . also should i switch to the elderbrock high flow base and runners?
Old Aug 4, 2012 | 12:07 PM
MaxpowerTA's Avatar
Axle/Gears: 4.11
Yeah if you get the hardware you need to burn roms Either Tunercat or Tunerpro will do the job. You will be hard pressed to make anywhere near 450 horse even with a 383 using the stock base and runners. I wouldnt go with the edelbrock base if i was to do it again I would get myself a FIRST TPI setup.
Old Aug 4, 2012 | 06:28 PM
No to sound dumb . What do u mean first tpi setup. This is going on 85 z28. I also have a tpi from 87 z28 and computer .this is my first fuel inj build. So It's a learning process . Have always build carb motors
Old Aug 4, 2012 | 07:41 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
to clarify, First, is an aftermarket intake that looks very similar to the stock TPI but with larger runners, base etc.
Old Aug 4, 2012 | 07:54 PM
Thank u, where u find it?
Old Aug 6, 2012 | 01:46 AM
MaxpowerTA's Avatar
Axle/Gears: 4.11
http://www.firstfuelinjection.com/
Grant2k
Jul 10, 2018 04:01 PM
italiano67
Dec 11, 2016 09:21 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
