Fuel rail o rings
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
Fuel rail o rings
Can I use standard o rings for the fuel rail or is there a kit? The ones that came out look oval. If there is a kit where can I get one?
Thanks.
Thanks.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel rail o rings
Need to be Viton fuel proof or similar construction
Fuel O rings available loose at most parts shops if you know sizes or take the old ones in
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Autozone sells Felpro ES70599 o-rings that come 4/pack, so you need four packs to replace all 16 o-rings on the injectors. I did this recently and they worked well.
