Adjustable fpr or not?
Old Aug 10, 2012 | 02:08 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I am having to replace the diaphragm in my stock for because of trash im assuming and just been sitting so long,I started the car finally and when I take off it does fine till I give it gas then it fall on its face and start bucking around and stuff and popping out the intake..it idles fine but just acts like it is running out of fuel when I gas on it...any other suggestions guys?
My other question is do y'all know a good place to buy a regulator kit because te ones I've found are just as expensive as buying am adjustable one..if anyone knows a good source lemme know,Thanks
Oh..I have a 91 tpi 305 t-5,fresh engine new injectors just so ya know what I'm working with
Old Aug 14, 2012 | 07:41 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Adjustable fpr or not?
I used a Holley 512-501 recently and the quality of it is acceptable. Not sure if that's your problem though. Test the regulator you have now by putting a pressure gauge on the rail. With the car running at idle and the vacuum to the regulator disconnected, the pressure should be between 40 and 47 PSI. When you plug the vacuum line back on, the pressure should drop between 3 and 10 PSI. Also make sure there isn't any fuel in that vacuum line.
Old Aug 14, 2012 | 08:23 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Holley parts are OK.
Old Aug 14, 2012 | 08:08 PM
southbay08's Avatar
We have adjustable fuel pressure regulators,, they are the stock replacement for the stock tpi's. We carry the diaphragms as well.
If you decide to purchase from us you will receive 10% off with promo code tg11.
Here is the link to the tpi parts that we carry:
http://www.southbayfuelinjectors.com...p=0&child=1497
If you have any questions please contact us.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
