Header advice
Header advice
Hi guys,
Since I'm a newbie when it comes to this stuff I know I need to come here for the best advice. I'm looking to put headers on my 89 305 Iroc. We just did the cam and changed the springs (not sure if this makes a difference when choosing headers). Any advice on what I should be getting? I checked out Jegs and saw Hooker headers 2210-4 for $980. I'd assume they're one of the better ones because they're the most expensive so you can see where my knowledge on this subject goes. Any help would be great!
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Header advice
you can go this route
http://www.jegs.com/i/Hooker-Headers...rentProductId=
http://www.jegs.com/i/Hedman/500/684...rentProductId=
if you buy headers only, your local exhaust shop can make you a y-pipe to fit
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Header advice
Forget Jegs and your local muffler shop. You want these : ^
