conflicting blm and wb02
I have a 383 with tpi, 7165 ecm running 6e mask. Small roller cam and 10.5 to 1 comp. My blm at idle goes to 108, but my wbo2 reads lean. If I adjust maf table1 to get the blm in line the motor runs rough and the wb02 goes dead lean. If I bring the maf table back up the motor runs smooth but the blm tries to pull out fuel. Do I ignore the blm at idle?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: conflicting blm and wb02
You may get more responses in one of the tuning forums.
