Weiand 7540 Stealth Ram
Old Aug 29, 2012 | 12:35 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Can you use the stock L98 fuel rails, injectors, and ECM with the Stealth Ram? Also, it says you need to use a "small cap" distributor. There's only two GM distributors i've come across in my time. The kind that has the coil in the cap, and the kind with the coil mounted externally. Is distributor with the external coil the "small cap" distributor?
Old Aug 29, 2012 | 10:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Weiand 7540 Stealth Ram
TPI ECM ,Wring and injectors .YES
Rails .No
need http://www.summitracing.com/parts/HLY-534-185/
or the HSR rails with non adjustable FP ( cheaper )
read the HSR bible
https://www.thirdgen.org/forums/alte...gal-whats.html
says you need to use a "small cap" distributor. Is distributor
Correct
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
JSDaddy189
Sep 26, 2015 03:50 PM
R3500
Sep 8, 2015 10:12 PM
