Schraeder Valve for fuel rail
Old Sep 12, 2012 | 04:31 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Anybody have a good used or where I might pick up a schrader valve for the fuel rail. I'm getting a small leak around the needle. I've tried tightening it, but no luck.
Thanks in advance
Old Sep 12, 2012 | 06:31 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Schraeder Valve for fuel rail
I got a box of them from O'Reilly's. I had exactly the same problem. They even leant me the little wrench to change it out. Now, I am hoping them don't need a special type for the fuel rail- I just got generic ones...
Old Sep 19, 2012 | 09:38 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Having same issue here. If I don't play with the valve when I take my pressure gauge off, it will spray gas everywhere, or just leak.
Old Sep 20, 2012 | 08:16 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
It's the core that you are replacing and how you can find them listed. There are differences in cores due to different materials used between AC systems, Compressed Gases and Fuels. The seals will be different per application. Generics will work for a little while but will not last as long as cores made for gasoline.
http://www.sunairindustrial.com/cata...lves_cores.pdf
http://www.alltiresupply.com/p-43-025.html
http://www.dieselorings.com/schrader...-1-8-mnpt.html
Old Sep 22, 2012 | 10:17 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Go to the dealership and get a GM part. You get the whole fitting, gasket, and cap. I bought one a few years ago and it was not that much money.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
