355 tpi iac adjustment
Old Sep 12, 2012 | 07:49 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so i finished my t5 swap but now everytime i have a really high idle i did a few test with brake cleaner spraying all vac lines an the intake an no high idle jump. So i did another test i pulled the air tube duct off the throttle body an stuck a rag in the bottom hole in the middle of the throttle body an the idle dropped a ton so it leaves me to think that the idle air control needs to be adjusted badly my idle is around 1200-1400 rpm
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 21, 2015 07:20 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 21, 2015 12:39 PM
Sanjay
Aug 12, 2015 03:41 PM
