leaking injectors???
Old Sep 18, 2012 | 12:36 PM
thirdgeniroc87's Avatar
Car: 87 IROC-Z28
Transmission: 5 Speed
Can someone please inform me of the proper procedure to check fuel pressure and what the pressures should be I'm trying to determine if I have leaking injectors. When I hook up gauge to fuel rail I get 42lbs ( that's without car running just prime from pump) after 5 minutes I was down to 32 lbs . Am I doingvthis correctly what should the pressures be and how long should it hold.. thanks guys
Old Sep 18, 2012 | 02:07 PM
b_the_j's Avatar
Car: 92 RS
Re: leaking injectors???
In order to rule out the pressure regulator or the fuel pump you should find a place to clamp those off after you prime it...then you can bet that injector leak is the case.
Old Sep 18, 2012 | 08:11 PM
southbay08's Avatar
another quick test for leaky injectors is to pull the plugs, if you have a wet
cylinder you have a leaky injector
Old Sep 18, 2012 | 08:23 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Don't feel bad, mine is way worse. My pressure drops to nothing within 2 minutes, but pretty sure it is the pump because it runs too good and the mileage is too good to be an injector, and when I clamp off the return, it still does it.
Old Sep 19, 2012 | 07:11 AM
Car: 87 IROC-Z28
YeAh I was borrowing fuel pressure tester but when it only dropped to 32 lbs after way over 5 minutes I am going to leave themmfor now atheist until I can iron out some other more important kinks lol. I did start the car and the results were as follows:
Just prime from pump 43.5 lbs
(well after five minutes dropped to but never less than 34lbs)
Car running dropped 8 lbs ended up at 35.5 steady
WOT pressure would rise quickly to about 43-47 depending on how I I revved it.
Seems to be right where it needs to be, also checked ohms on fuel injector and all are within tolerance.
jklein337
Sep 19, 2018 06:23 PM
92projectcamaro
Jan 18, 2016 08:00 AM
ramicio
Sep 6, 2015 11:25 AM
greenyone
Sep 2, 2015 03:39 PM
mike_c
Aug 27, 2015 04:32 PM
