Stalling headache!!
Old Sep 27, 2012 | 12:08 PM
87CamaroLT43's Avatar
Car: 88 GTA, 92 Formula
Engine: 355, LB9
Transmission: WC T-5, WC T-5
Axle/Gears: 3.27 LT1 Rear
Stalling headache!!
Hey guys. Ive been battling with my 92 Formula for a while now with this stalling problem.
It's a bone stock lb9 with the 7730 ecm.
My issue is cold start. It will not stay running when cold unless you tip in the throttle and keep the rpms at 2k. After about 3 minutes you feel the car smooth out and it will maintain idle but surge a bit.
I've already chased injectors, iac, map, tps, mat, and fuel pressure reg. All the sensors are within range. And fuel pressure is around 45-48 psi. Anyone have any other ideas what could cause this?
Old Sep 27, 2012 | 12:26 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Stalling headache!!
Is there a cold start injector?
Old Sep 27, 2012 | 04:01 PM
Engine: 355, LB9
No. 92 LB9 with the 7730 ecm do not have cold start injectors.
Old Sep 27, 2012 | 07:20 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I had a similar issue and it was my EGR valve had gotten all crusty with carbon buildup...check that out and see if its functioning properly
Old Sep 28, 2012 | 12:01 AM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Get the ecm tested. It will eliminate the obvious at least. Oil pressure sensor could have an effect on this.
Old Sep 28, 2012 | 03:39 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Ok, sorry I missed that. When you say the sensors are within range do you mean you checked them with a meter out of the engine, or you are using an OBD monitoring tool to see what the ECM is reading them as? I have a coolant sensor in the garage that seems to check out until you put it in the engine; then it's suddenly -40F.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
