oil dip stick chewing
Old Sep 28, 2012 | 02:04 AM
mike40sm2's Avatar
Car: 1986 Iroc Camaro
Engine: 350+
I recently Rebuild my 350 tpi engine put an after market chrome engine oil dip stick in, and found after starting engine it chewed the end of the dip stick
I was lucky manged to remove it (Just) as it was jammed replace it with old one which is fine.
Any idea's as would like a chrome one but now scared to try another one incase it damages the engine
Old Sep 28, 2012 | 03:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: oil dip stick chewing
Was the new one identical to your old one?
There are different styles ( lengths ) of dipstick depending on the age ( version) of your engine block
Old Sep 28, 2012 | 05:12 AM
mike40sm2's Avatar
Engine: 350+
I must admit i never looked that hard at it when it came from the States
I have checked on website all they tell you is will fit SBC tried looking for SBC 350 TPI nothing comes up apart from standand ones i wanted a chrome one ?? Can't really keep ordering up dipsticks hoping one will fit mine, not that Rich.
Cheers
Old Sep 28, 2012 | 07:10 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
what year is the engine? there is supposed to be a sleeve about 6" long that goes into the dipstick hole before putting the dipstick tube in.. this sleeve's whole purpose is to keep the dipstick away from the crankshaft. i know the older (80 and older) engines with the dipstick on the driver's side all have this sleeve, but i don't know about the newer blocks with the passenger side dipstick.
Old Sep 28, 2012 | 08:33 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
All my 1 pce RMS engines have the dipstick hole ( pass side ) down by the pan rail and a long tube whereas on the earlier engines w/drv side dipstick the hole is up level with the head and have a shorter tube
Looking at the eBay listings it appears the early 80's engines (2 pce RMS ) with the pass side dipstick are the same as the '87+ 1 pce RMS blocks
Old Sep 28, 2012 | 01:06 PM
mike40sm2's Avatar
Engine: 350+
Thanks guys
I think it may have been my own fault as just check back on my Ebay account in 2010 and the dip stick i ordered was for early SBC up to 85 mine was a 86 TPI with p/side stick and yes it does have tube that was not the problem, i have ordered another one flexi says its for 86 onwards but will check before install this time.
Thanks for the help guys
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tyeo098
Nov 30, 2015 06:27 PM
Ragtop Man
Sep 12, 2015 12:23 AM
snakeshooter
Sep 7, 2015 11:13 AM
