Code 43
Old Oct 15, 2012 | 08:05 PM
phidoe2000's Avatar
Code 43
I have a salvage titled camaro that seems to be a meld of several different years. It is a map car, tpi, and I believe a 305. I have a code 43. I've checked the wiring to the knock sensor and get the 5v reference voltage. I've replaced the knock sensor as well. This car also has VATs which I bypassed....I mention this if it helps identify the year of the motor. Since I bypassed the vats the car now starts slowly but does run ok. Smells rich, mileage has suffered. The timing is at 6 as recommended. Any ideas?
Old Oct 15, 2012 | 08:24 PM
phidoe2000's Avatar
Re: Code 43
I also should mention that I needed injectors about two years ago when I thought my engine was a 350. I put 21 lb injectors in. All the issues I had at that point were fixed. Now I realize the car should have 19 lb injectors in it, but the code 43 is recent. I'm not sure if it would contribute to my current issue or not.
Old Oct 16, 2012 | 12:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Code 43
http://www.chevythunder.com/maf_esc_module_code_43.htm
Old Oct 16, 2012 | 05:10 AM
phidoe2000's Avatar
Re: Code 43
Thanks, but my car is a MAP car.
Old Oct 16, 2012 | 07:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Code 43
http://www.chevythunder.com/esc_map_code_43.htm
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
