tpi bolt problem
Car: 86 chevy 28 camaro
Engine: 305 tpi
tpi bolt problem
im puttin the runners back on and cant figure out where the long bolts,medium,short ones went anyone have a diagram?please need car running asap
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: tpi bolt problem
If you find yourself with a handful of mixed-length TPI Torx head bolts, there's an easy way to sort them out. The reason the bolts are multiple length is that the runner flange thickness on the runners to intake base varies. Just like a puzzle, with the runners loose on the bench, keep shifting the bolts around until the exact same amount of thread on each bolt is exposed out the backside of the runners. The locations will now be correct.
84z96L31vortec
Aug 20, 2017 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
