no spark
Old 10-18-2012, 01:17 PM
oldschool226's Avatar
Car: 86 iroc and 84 sport coupe
Engine: 305 tpi and 3.8buick turbo
Transmission: 700r4's
Axle/Gears: 2:77 and 4:11
no spark
Hey guys i have an 86 5.0 tpi I bought as a basket case I've got it back together but i don't have any spark. I replaced the coil, ignition module,and magnetic pickup. I have power to the distributor, motor turns over, and fuel pump is working. I' also tried with the est disconnected but nothing. When I was putting the wiring back in I was left with to larger wires that look like they go back through the firewall next to the heater box I have not messed with them yet. Does anyone have any ideas?
Old 10-18-2012, 10:03 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Re: no spark
Do you possibly have your IAT connected to the distributor by mistake? Heard it happen before and happened to me too. The connectors are the same and they just happen to be very close in location. Double check that for sure.
Old 10-19-2012, 03:39 PM
Re: no spark
Whats iat stand for and how many wires are on that connection? Thanks
Old 10-19-2012, 05:21 PM
Engine: 350 L98/LS2
Re: no spark
IAT=intake air temperature. Located at the rear of the plenum. And it's 2 wires. Looks exactly like the distributor connector
Old 10-25-2012, 08:37 PM
Re: no spark
Iat was hooked up right. Took dizzy out checked all the wires reread manual found white @ red wires coming off mag pickup coil yellow red. Manual says yellow has diferent polarity than white. Got different coil white white no spark. Back out with the dizzy rechecked wires duh had ignition module wires crossed. Yea we got spark and it runs yea!!!! Thanks for the ideas.
RedLeader289
05-28-2019 01:47 PM
Bubbajones_ya
10-25-2015 08:01 PM
HoosierinWA
10-07-2015 10:15 AM
meeklay812
10-01-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Quick Reply: no spark
