does compression effect ecm control ?
Old Nov 8, 2012 | 12:19 PM
hoagie's Avatar
Car: 88 gta
Engine: dog 305
Transmission: auto
Axle/Gears: 410
if i use 58 cc heads and raise compression will it effect ecm control ? thanks
Old Nov 8, 2012 | 01:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: does compression effect ecm control ?
If heads and everything else remains same then it shouldnt change too much assuming you went fron 64cc stock to a milled 58cc.
If its a different head then it may have different flow rates and chamber design requiring different fuel amounts and timing changes. In that case you need to tune it.
Ecm dont care what you are running but its only programmed for one specific engine. Small changes it may beable to compensate fuelin levels like in maf sensor cars but big changes may need programming changes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
