305 tpi starts but wont run
Old Nov 21, 2012 | 09:14 AM
morris living's Avatar
hey guys, I am new to the forum and dont know a lot about tpi systems, but I have a big problem and could use some help. I just finished up a engine swap into my 56 nomad. the car ran fine, except for a problem with the fuel pressure. It was very eratic. I finally figured out that I needed to run the return line to the tank instead of running it back into the feed line out of the tank. but after I got it all back together, It starts, but wont run over a second or two,before it dies. it holds good fuel pressure at about 43lbs, the noid lights fire rite up untill it dies, the dis. retains power all the way through the process. I have replaced the rotor cap. rotor brush, plugs, ign. module . the scanner says no rpm count. it ran fine untill I changed the line. any ideas
Old Nov 22, 2012 | 05:51 AM
polymer52's Avatar
Re: 305 tpi starts but wont run
Did the donor car have VATS?
Old Nov 22, 2012 | 07:18 AM
Thats one thing I dont know, but it has been running for a while, I even drove it to two shows.this happened after I rerouted the return line. How can I check to see if vats is the problem?
Old Nov 22, 2012 | 07:44 AM
I understand that the fuel or the fire is turning off, but from all the test I have done, I cant tell. But the fuel pressure is holding rite through the dying part, so i am leaning toward the fire. I stuck a used plug in # 1 hole, and it fired strong rite up till it died. but I cant tell if the plug quit fireing to cause it to quit or not. its a new engine, so it dies rather quickley.
Old Nov 22, 2012 | 04:33 PM
polymer52's Avatar
If it ran at one time then vats is most likely not the problem.
Are you getting any codes?
Old Nov 22, 2012 | 06:59 PM
scanner is detecting code for no rpm count
Old Nov 22, 2012 | 09:29 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
What kind of distributor are you using? Sounds like the ECM isn't seeing the ignition pulses from the distributor.
Old Nov 23, 2012 | 05:16 AM
polymer52's Avatar
Pull the distributor cap and make sure the distributor is actually turning ie no stripped gear.
If ok then check for pulses at the tach wire.
Old Nov 23, 2012 | 10:04 AM
the engine cranks and runs perfect untill it dies. I checked for any wear in the dis. but no play sideways and maby .10 up and down . new cap and brush and new module. hei type.
Old Nov 23, 2012 | 11:43 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
So you don't have the computer controlled distributor installed? You can't run a stock HEI dist with the ECM as it needs to be able to control the advance and it needs to "see" the tach signal from the pickup in the distributor. There is no vacuum advance on the stock computer controlled unit, so if you have a vacuum advance then you have the wrong distributor if you want the computer to run the engine.
Old Nov 23, 2012 | 12:39 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
If it ran before then having the wrong distributor is not the problem. If he had the wrong one it would have never ran in the first place. It has to be from a part failing. Maybe a wire was unplugged and never plugged back in when he redid the fuel line.
Old Nov 23, 2012 | 02:00 PM
polymer52's Avatar
Is the fuel pump shutting off before it dies and does it hold pressure when its NOT running or just when its running? It should hold pressure when shut off.
If so put the fuel line back like it was to start with and see what happens.
Old Nov 23, 2012 | 03:15 PM
the dis. is correct, it does not have a vacume adv. it also holds pressure on the pressure guage for quite a while after it dies, thats why I am thinking it has to be fire. I thought it might be the pickup coil, or let me ask a novice question, sence tjhe only thing I changed was the fuel return line, what would happen if I have a partialy blocked line or something? or does the computer have a shutoff if the pressure gets to high?
Old Nov 26, 2012 | 08:04 AM
today I'm going to take the return line loose just to see if thats the problem
Old Nov 27, 2012 | 07:17 PM
today I took the return fuel line off , and ran it into a bucket, but no change. the engine starts rite up, and runs for about a second, and dies.
Old Nov 27, 2012 | 07:46 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Will it run if you step on the accelerator? Mine occasionally does what you're describing, starting up but not idling. I just turned the adjuster screw on the throttle body to open it up a bit. If that's the case, you just need to reset your tps and iac.
Old Nov 27, 2012 | 09:02 PM
it doesn't matter what i do, it dies like you hit it in the head with a hammer, but it starts rite back up no problem.I've even tried keeping the switch turned to start longer than needed, but it just died. the only code it gives is no rpm signal.
Old Nov 27, 2012 | 10:12 PM
hhhhhhhmmmmmm, I thought surely that at least one of you guys had seen this before.
Old Nov 27, 2012 | 10:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
code 42 ? you dont state what ecm you are using 1227165 or 1227727 or 730. I didnt see the answer weather your fuel pump runs more than just the 2 sec prime ? At first seeing the post I though the tank wasnt vented but you eliminated that trying to run with the return line off. Drp stops at 400 rpm but you can check the voltage cranking on the purple and white wire dist ref out of the icm or at the ecm. Injectors will not pulse without this tach signal 5v square wave signal.
Old Nov 28, 2012 | 08:02 AM
I will check the voltage today hopefully. the pump holds pressure all the way through the process. I'll ckeck to see which computer I used, but I think it is the 730.
Old Nov 28, 2012 | 12:07 PM
Engine: Lb9
Transmission: M20
on a 730 the dist ref is on D8 purple/ white . if the pump just does the 2 second prime only you should be looking at the oil pressure switch / circuit .
Old Nov 30, 2012 | 08:14 AM
I was rechecking everything today, and found that my dis. cap dosen't have the center spade going to the coil grd. will this cause the problem?
Old Nov 30, 2012 | 06:01 PM
Engine: Lb9
Transmission: M20
Im not sure what your saying is missing the wire coming from the icm that controls the coil ground ? or are you saying your missing the coil wire that goes to the rotor ?
Old Dec 1, 2012 | 08:53 AM
the dist cap has a grd. in the black 3 spade plug the center wire is a grd. is was missing but I put one in and changed the coil and the module , but nothing helped. I've got .5 volts at th purple and white wire, and I checked the coil in the bottom of the dis. and every thing test good. I dont know what else to do, except put a ecm in it
Old Dec 1, 2012 | 10:09 PM
355_L98_GTA's Avatar
Car: 1984 TA
Engine: 355 Carb
Transmission: 700r4 Built 2200 stall
Don't these engines ecms require a signal from the oil sending unit to run the fuel pump or do you have it wired to the ignition through a relay.
Old Dec 2, 2012 | 09:12 AM
oil pressure is wired through engine harness for the car. The oil pressure switch evidently has been removed from the prom
Old Dec 2, 2012 | 09:21 AM
Engine: Lb9
Transmission: M20
Old Dec 2, 2012 | 09:47 AM
Engine: Lb9
Transmission: M20
At what address in the $8d .bin is the change for the ecm not to receive fuel pump sense 0x24c bit 5 ?
http://www.hotrodlane.cc/newtech/tun...elcircuit.html
Old Dec 4, 2012 | 05:52 PM
Does the housing for the ecm have to be grounded?
Old Dec 4, 2012 | 06:01 PM
Engine: Lb9
Transmission: M20
no don't ground the ecm case
Old Dec 4, 2012 | 06:27 PM
going to try grounding body tommorrow, and I got another ecm to try. after that, I guess it'll be edelbrock and aluminum intake time, I know without a doubt I can make them run.
Old Dec 5, 2012 | 03:50 PM
well , the problem gets more flustrating every day. here's what Ive tried so far
checked fuel pressure and its ok before during and after running.
changed timing module
changed coil
changed ecm
changed dis. module
changed rotor cap
changed,rotor brush
12v to dis is constant ,cranking,running, and dying.
ive got .5 volts to dis on purple and white wire
plugs spark through running and dying process
noid light pulses through process same as plugs
scanner shows 180-200 rpm wheen cranking
scanner shows about 6 degrees advance chen cranking.
put in fresh gas
changed fuel filter
scanner shows no codes
Old Dec 5, 2012 | 04:09 PM
Engine: Lb9
Transmission: M20
If the cranking speed is accurate you need at least 400 rpm to start the engine.
Old Dec 6, 2012 | 07:05 AM
It does start and run, so The scanner may be off . I dont knoe how to check it. oh buy the way, I put the dis in a vice and hooked it up to a battery, it sparked really good on all 8. I cant think of anything else to look at. WE even called a GM high perf. teck line,and tried all their suggestions, but no help.
Old Dec 6, 2012 | 07:10 AM
this problem totally makes no sence. what am I not checking?
Old Dec 6, 2012 | 07:51 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I was thinking (I could be wrong) that 400RPM was the threshold where the ECM decided that the engine was running and no longer cranking.
What happens when the ESC wire is disconnected, same thing exactly? I'm thinking that when it fires, the ECM advances the timing a bunch. Since there is no crank position sensor, the ECM depends upon the timing to be set at a known location, hence the 6* you see when cranking.
Outside of that, if the ECM is "seeing" ref pulses from the dist and is pulsing injectors and sparking the plugs when it dies, then it's pretty much down to a fuel supply or timing issue.
Did you try starting fluid to see if it would keep running?
Old Dec 6, 2012 | 08:38 AM
I have tried timing at several settings, but no help. I will try force feeding it this morning.
Old Dec 6, 2012 | 05:12 PM
this morning I took some berimans, and sprayed a bunch in the pvc hose and it ran to or 3 seconds, so I had a friend spray some in the hose while I was cranking it and it kept running, then it kept runningafter the berimans burned out. it is stil running like crap, but it is running. try to explain that. now it runs like crap as long as the oxygen senser shows lean, but when the senser shows rich, it smooths ouy a lot.
Old Dec 6, 2012 | 05:29 PM
92camaro305seth's Avatar
How do I post something the website New user sorry the ramdom one
Old Dec 7, 2012 | 04:32 PM
Iput another set of new plugs in it today, and set the timing at 38 degrees full advance, and it seems to be running pretty good. but it does run rich untill it warms up.
Old Dec 8, 2012 | 09:36 AM
can I unplug the 9th injector without any problems?
Old Dec 8, 2012 | 11:42 AM
  #42
Engine: Lb9
Transmission: M20
the ninth injector can be unplugged it is not hooked to the ecm it is controlled during cold starts bye the cold start switch. You stated your are running tpi sd so the ninth injector is not needed on $6e 89 maf and 90-92 $8d calibrations.
Old Dec 8, 2012 | 06:29 PM
  #43
I thought it might be the reason it is running rich when cold.
Old Dec 12, 2012 | 08:14 AM
  #44
I thought it was running rich when cold, but the scanner says its lean. it just choakes down and dies, untill the oxy. senser kicks it into closed loop then it idles fine. But if i put it in gear or the fan turns on, it will idel down from the load, and not recover. no codes are showing
Old Dec 16, 2012 | 08:44 PM
  #45
`drove the 56 to town and back a couple of times this weekend, and it seams to go down the road good, but it still has trouble learing to idle rite. Ive set the idle air control at 1*1/8. and the tps at .65 volts, what else can I do?
Old Dec 17, 2012 | 12:14 AM
  #46
Engine: Lb9
Transmission: M20
there is no learn for the idle speed in $8d but there is for definition $88. There will be alot of things that will affect it vss or lack there of, vacuum leak, timing lazy iac, carbon buildup in the iac passage. Have you set the min idle speed ? On a 730 ecm if someone has put a older 85-89 tps with the elongated adjustment slots you could adjust the tps but the range is 0.660VDC to 0.760VDC at idle.
A eprom calibration can affect idle quality as well I have had good luck with some broadcast codes automatics in manual trans cars but it depends on the tune. It is better to start with the closet and newest broadcast code and tune from there.
Old Dec 17, 2012 | 08:16 AM
  #47
I don't understand the $8d or $88. my ecm is the 165.
Old Dec 17, 2012 | 09:10 AM
  #48
Engine: Lb9
Transmission: M20
I'm just giving information off what you provide an there is some lacking. The 165 ecm you will need to set you min idle speed then set the tps to .54 . Disregard the definitions listed your ecm still does not have a idle learn. Is the memcal in your ecm a unmolested factory memcal ? If so what are the letters on the top of the silver sticker ? Is this car a manual or automatic ? are you using a 2k ppm vss ?
Old Dec 24, 2012 | 06:15 PM
  #49
well, I can drive the 56 now, as long as I slip it up into netural when I stop. I cant find anything wrong with any of the settings, so I must have got a bad IAC unit. How can I check it to see if its working?
Old Dec 24, 2012 | 07:16 PM
  #50
Engine: Lb9
Transmission: M20
Not sure if you have a 700r4 but if you do and go into lockup it's not a vss issue. If you can datalog you can watch the iac and vss. you can test the iac commanded movement at idle with a iac noid but its just a bipolar led with a 1k resister on iac 1 and 2 coil.[/U]
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
