The kind of obd code reader is easy to use, and cheap?
Old Nov 26, 2012 | 03:38 AM
alinazhou's Avatar
Car: volvoXC90 T6
Hello, everybody, my name is alinazhou, I'm confused,I want to buy An OBD II Code Reader to Check my Car , we can search a lot about obd code reader products, which one is suitable for my car? Any suggestions?
Old Nov 26, 2012 | 05:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: The kind of obd code reader is easy to use, and cheap?
No 3rd Gen was OBDII
You don't need a code reader , all you do is stick a paperclip in the ALDL connector and the check engine light will flash the codes for free
https://www.thirdgen.org/forums/tech...wbie-what.html
Old Nov 26, 2012 | 08:28 PM
alinazhou's Avatar
Car: volvoXC90 T6
What? I do not understand,If my car fails, obd ii quickly detected to the vehicle where there is a problem,save time, and do not charge extra repairman
Old Nov 26, 2012 | 10:25 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What?
Your profile states you have a Volvo
This is a 3rd Gen GM F-BODY Forum ,
none of which had OBDII so a OBDII reader will not work on them
If you are actually inquiring about a code reader for a Volvo then go to a Volvo Forum
Old Nov 26, 2012 | 10:42 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Alinazhou, go here and ask them: http://volvoforums.com/forum/
I get that its a thirdgen, but you are coming down a little hard on a guy who probably barely speaks english, heck for all we know he's posting this through google translate.
Mods should just lock this thread so it falls into obscurity.
NORTz89
May 20, 2020 03:51 PM
italiano67
Dec 11, 2016 09:21 AM
Greg '85 T/A
Aug 14, 2015 01:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
mizz0313
Aug 12, 2015 06:45 AM
