TPI Assembly guide?
Old Nov 30, 2012 | 03:40 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
TPI Assembly guide?
Does anyone have a link some sort of TPI assembly guide? I have a bunch of parts and a bolt kit, but not all are marked. If there's a blow-up diagram anywhere, that would help a ton. I know I have an 85-86 base, a fuel rail with the fitting for the cold-start injector, the runners have the hole for the cold start injector, and the plenum has the opening at bottom between the throttle openings. I plan to block off the cold-start stuff, as I won't be using a stock ECM.
-Dave
Old Nov 30, 2012 | 04:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Assembly guide?
The hole in the plenum in the front in for the 85-88 iac manifold vacuum passage. Buy a fuel rail plug and runner plug to eliminate the 9th csi if you are compensating for cold start condition in your tune.
http://www.ebay.com/itm/Camaro-Fireb...0631ae&vxp=mtr
http://www.chevythunder.com/fuel%20i...%20pg%20AA.htm
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
