shaking at highway speed
Old Dec 3, 2012 | 09:56 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
when i get on the highway and give it gas to get up to speed my car shakes bad.i know its the motor or tranny. ive put every sensor new on this thing and nothing helped. does the same thing. i adjusted the tv cable. and does the same thing.
Old Dec 5, 2012 | 07:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: shaking at highway speed
Manual or Automatic?
does it shake in Neutral when you rev it up?
Take is on the road, get it up to speed when it's shaking really bad, and put it in neutral, does it still do it then?
It's possible that your drive shaft threw a weight.
Are you sure that youre wheels are balanced? If a tire throws a weight, the shaking can get really bad.
Old Dec 5, 2012 | 07:54 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
noticed this morning it does it at low speed too. but i will but it in nuetral when it starts it and get back to tou.
Old Dec 5, 2012 | 08:14 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Is it " in the steering wheel" when you drive? Or do you feel it "In your butt", shaking up through your seat?
Old Dec 5, 2012 | 08:31 AM
91 outlaw's Avatar
Car: 1991 Camaro
Engine: 355 5.7L
Transmission: Turbo 350
Axle/Gears: 373
could be a few things driveshaft, wheel out of balance, bent rim, tire out of round, caliper sticking really need to know if its in the wheel or seat
Old Dec 5, 2012 | 09:08 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Yeah, I was about to mention the bent wheel. I had an Eagle Talon that had the same issue, bent rim made it shake like crazy at speed, felt it through the steering wheel.
Old Dec 6, 2012 | 12:14 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
noticed its seems to be doing it when goes into overdrive.
Old Dec 6, 2012 | 01:07 PM
91 outlaw's Avatar
Car: 1991 Camaro
Engine: 355 5.7L
Axle/Gears: 373
Ok so that eliminates the bent rim bad tire or out of balance. Driveshaft is still a possibility I am not going to jump up and say transmission. When your car goes into od the rpms drop low and a load is still being applied how confident are you about the condition of your plugs? 1st thing I would do is get some carb cleaner or starting fluid plus seafoam. Clean out your fuel system throughly I usually put 1/4 in tank and 3/4 through the brake booster vaccum of seafoam. pull the air cleaner assembly get into the tpi with a brush and carb cleaner. Idle control valve could be caked with carbon. Clean the system run the hell out of it to blow all of the loosened carbon out. This is what I would try first.
Old Dec 7, 2012 | 09:57 AM
tpi84stepside's Avatar
I had one bad injector that caused a slight misfire that was hardly noticable until it went into overdrive...shook the whole truck..New injectors solved the problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
