Comp Cams Magnum series for TPI
Old Dec 9, 2012 | 03:06 PM
EDscamaro's Avatar
Car: 89 rs
Engine: 357
Transmission: M20 muncie
Axle/Gears: 3:42 posi
Hey everyone, this subject is beat to death but I have a mild 355 motor in 89 camaro. It is currently carburated and looking to put TPI back on. Current cam is Comp cams CL12-212-2. single pattern 480 lift, 230 duration @ 110 ls. power range is 2000- 6000rpm. Motor pulls about 15inchs vacum at idleing at 650rpm. Not a choppy cam- but it idles well. My question is.. Do you think a MAF TPI can compensate?
my motor is mild- sb 355, has summit vortec heads, comps magnum cam, msd HEI, heddmans hedders. compression 9.1 . My donor TPI is from 87 iroc 305, I took complete dash, ecm wiring and everything under hood for swap. I will correct the prom and use 24lbs injectors and 350 knock sensor.
This is costly, time consuming swap but all things considered it factory bolt ons.
Old Dec 9, 2012 | 03:45 PM
Re: Comp Cams Magnum series for TPI
No.
TPI will HATE that cam. Major mismatch.
There is no "compensate". Only, work together, or fight each other.
Old Dec 9, 2012 | 08:53 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
You would need opened up aftermarket TPI parts to really make use of that cam's power range.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
