car wont idle please help
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Axle/Gears: 9bolt BW 3.45 (G92)
Ok so Ive been reading posts for about 3 weeks now about an intermitent problem my 87 iroc has.
It stalls on cold and or warm conditions. It gets me to work still but between this random problem combined with a burnt power steering pump my car is a death trap. Since I work at night, when I actualy get time to just check it out its fine, making it harder to diagnose.
If it wont start I have to pump the gas like a carb. When running if I let off the throttle it shoots to zero rpms almost instantly. I gotta pump the throttle a few times a second to keep it running but sometimes after driving it idles fine. Until I restart the engine later it sometimes doesnt wanna fire up without help.
As far as parts, I have installed both power and burnoff relays for MAF(from Chevy), installed IAC today, and checked TPS voltage .5 @ idle 4.3 @ WOT.
I disconnected the timing wire and the iac and the car ran extremely rough with a strobing check engine light. Still wouldnt idle. Did the paper clip, 30 sec wait, disconnect iac, fire engine.
Also tried disconnecting the MAF sensor and it wont idle.
Since last weekend when I touched it last, I went this whole week without the problem until just after I removed the airlid and MAF plug to installl the IAC. Im almost convinced its either the MAF plug or MAF itself. Anyone have any suggestions? 3rd owner 79k-166k
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Re: car wont idle please help
Guess ill buy MAF and sensor connector, was hoping to avoid buying the MAF
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
That would indicate it has too much fuel. Having your foot on the gas while cranking the engine over shuts off the fuel supply.
How good are your fuel injectors? Have you tested them? May be leaking.
FWIW,
you can't " pump gas " on a EFI engine like you can on a carb engine ;
There is nothing to squirt the fuel in on a TB like there is a carb does so hitting the pedal does the opposite to what it does
with a carby; it lets more air in , not more fuel.
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
yeah I put a new IAC in. Thanks for diagram Im going to get a voltmeter I didnt test the MAF.
btw sorry next time ill say pump the air pedal, lol jk
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
pump the air pedal ? while cranking or running rapidly pumping the throttle will result in a accelerator pump shot.
Car: 1989 Pontiac Trans Am GTA
Engine: 2001 ls1
Transmission: built 4l60e with stall
Axle/Gears: 4:10
Also have you performed any recent work on the engine and what do the plugs look like is this tpi or throttle body
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Tpi as listed in profile. Previous owner put new injectors in 85000+ miles ago. No mods.
Ill check the fuel presssure and look into checking the injectors.
Car: 87 Camaro Z28
Engine: TPI 350 bored .030 over
If it's stalling randomly check your minimum idle adjustment since you installed a new iac. I had the same problem after installing a new iac and whoever owned my car before had adjusted it all wrong. Also check all your vacuum lines for leaks and make sure your spark plugs aren't fouled.
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
My car was a little different because it was in police service for over 10 years, but I had the exact same problem. For me it was the pickup in the distributor. When I tried to remove it, it just crumbled into dust...all the hours of idling in heat had really worn it out. I just got a replacement distributor and it has ran perfect ever since.
Engine: 2001 ls1
Axle/Gears: 4:10
any ck engine lights? I should have suggested getting it ran for codes first thing.
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
been a week since i believe i fixed it. visualy looked at maf + screen few times looked fine but i used MAF cleaner on sensor and i think that was the problem. i also noticed sludge behind the butterflies for the throttle body. took the 4 bolts off and cleand the tb's backside.
now car idles, just high.
i installed a new iac but also broke it so i put the old one back in so im thinking the bad idle now is bc of IAC.
by the way parts installed have been attempts to cure the problem.
