no spark
Old Dec 11, 2012 | 03:00 PM
kimberanton's Avatar
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
no spark
my car was running fine then shut off without warning now it wont start, i shot it with starter fluid and nothing, everything is brand new, any help would be awesome, thanks
Old Dec 11, 2012 | 03:05 PM
bigbubba1488's Avatar
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
How does your coil look. Fill me in with whats new with your ignition set up
Old Dec 11, 2012 | 03:16 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: no spark
What about your ignition control module under the distributor cap ? Sudden no spark issues usually come from that
Old Dec 11, 2012 | 03:27 PM
Re: no spark
entire spark system is brand new
Old Dec 11, 2012 | 03:28 PM
Re: no spark
GM said i might have snapped my timing chain
Old Dec 11, 2012 | 03:29 PM
Re: no spark
i do have another ICM though
Old Dec 11, 2012 | 03:31 PM
theNMBR27's Avatar
Re: no spark
Does the engine turn over? If it does the timing chain is probably fine and its very unlikely that you'd just break the chain. Make sure all your grounds are good on the back of the cylinder heads and that nothing else is unplugged.
Old Dec 11, 2012 | 03:34 PM
Re: no spark
it turns over and all grounds are fine, just checked them
Old Dec 11, 2012 | 03:38 PM
Re: no spark
it was running then tink, then it just shut down
Old Dec 11, 2012 | 03:41 PM
theNMBR27's Avatar
Re: no spark
You must have a wire off somewhere. Any after market ignition parts or all stock
Old Dec 11, 2012 | 03:43 PM
Re: no spark
all stock, just checked the wires again, everything is hooked up
Old Dec 11, 2012 | 03:44 PM
Re: no spark
i replaced them all to stock specs
Old Dec 11, 2012 | 03:52 PM
theNMBR27's Avatar
Re: no spark
Can you take the module out of the cap and have it tested. Advance auto/ autozone and oreillys can all test it. Don't let them tell you other wise.
Old Dec 11, 2012 | 03:59 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
Same thing happened to my 85 and was a bad ICM so give that a shot
Re: no spark
i have a good ICM, ima go replace it real quick
Old Dec 11, 2012 | 04:06 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
Old Dec 11, 2012 | 04:30 PM
Re: no spark
replaced it and no change im out of ideas
Old Dec 11, 2012 | 04:38 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
pull a plug a touch it to the header while you crank it to verify no spark and lets go from there
Old Dec 11, 2012 | 04:42 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
Also take a pic of you distrib. for me I wanna see if you have a top mount coil and if you do take the cap and and see if something may have fried
Old Dec 11, 2012 | 04:45 PM
Re: no spark
no spark
Old Dec 11, 2012 | 04:46 PM
Re: no spark
checked it all when replacing the ICM, everything is fine, it only has 4000 on it
Old Dec 11, 2012 | 04:48 PM
Re: no spark
coil is off to the side
Old Dec 11, 2012 | 04:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: no spark
Start with the basics check for power koeo on the coil grey connector pink wire and trouble shoot from there. Im not sure how many kv your spark tester is or adjustable gap but use a 40kv tester. Not to second guess you but have you done a compression test or actually check for spark or are you just throwing parts at the car?
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Dec 11, 2012 | 04:55 PM
Re: no spark
which one do i check, theres 4
Old Dec 11, 2012 | 04:56 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
So if your coil is getting juice then your problem is going to be somewhere within the cap and rotor because it's not connecting to send the spark to the wires just make sure before you start ripping into that the wire is securely connected from the coil to the cap
Re: no spark
i also have another coil
Old Dec 11, 2012 | 04:57 PM
Re: no spark
does the key need to be in the on position, then check the pink wire?
Old Dec 11, 2012 | 04:58 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
Do you have all of the old parts from your tune up?? If you do the easiest way to check it, is to slowly start putting them back on until the car starts. That's how I would do it it should only take about an hour or so but start from the simplest things first
Old Dec 11, 2012 | 04:59 PM
Car: 88 Z28 Sport
Engine: 350 TBI
Re: no spark
If you want to check for power I would think so, It wouldnt be a constant
Old Dec 11, 2012 | 05:00 PM
Engine: Lb9
Transmission: M20
Re: no spark
yes as stated above key on engine off
Old Dec 11, 2012 | 05:02 PM
Re: no spark
check the power to what? the coil
Old Dec 11, 2012 | 05:03 PM
Engine: Lb9
Transmission: M20
Re: no spark
as stated in post #23 yes the power to the coil
Old Dec 11, 2012 | 05:08 PM
Re: no spark
pink wire has 11.88 volts
Old Dec 11, 2012 | 05:13 PM
Re: no spark
coil has power and wire didnt so its between coil cap and dist
Re: no spark
ill replace the coil reel quick
Old Dec 11, 2012 | 05:18 PM
Engine: Lb9
Transmission: M20
Re: no spark
your battery surface voltage is a little low , you can check the primary and secondary resistance of the ign coil. Im not sure why you are unwilling to test anything but if you insisted on being a parts replacer not a mechanic good luck with your repairs.
Old Dec 11, 2012 | 05:38 PM
Re: no spark
went side to charge the battery and all relays and other thing started clicking and humming
Old Dec 11, 2012 | 05:39 PM
Re: no spark
i have all parts i took off
Old Dec 11, 2012 | 05:40 PM
Re: no spark
ive went through the entire wire harness 4 times, all wires are fixed and pluged in
Old Dec 11, 2012 | 05:46 PM
Re: no spark
i have DMM but i dont how to use it all that well, my mechanic is on vacation
Old Dec 11, 2012 | 06:07 PM
Re: no spark
im just going to sell it or buy a new wire harness, 2000 as is
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
