question about 1.6 rockers
Old Dec 12, 2012 | 09:32 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Ive read the stickies and did a search and couldn't come up with an answer
My car was previously built (not by me) for 1.6 rockers. I just called the guy that owned it to ask him some questions and one of the things we talked about was rockers. He says everything is there, just need the 1.6s themselves. my question is. I know the car will need a tune to get everything out of the modification. but, will it be drive-able? I can deal with it running a little rich until I get it in for a dyno-tune. was just curious about this
Old Dec 12, 2012 | 10:30 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: question about 1.6 rockers
1.6 rockers should be within the realm of the stock ECM to handle. If anything I would imagine it would run a little on the lean side, as it's extra air you're adding, not fuel.
Old Dec 22, 2012 | 11:14 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What does "Built for 1.6 rockers mean"?
Old Dec 31, 2012 | 05:09 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I wouldn't put too much into that " built for". If its a TPI MAF good, otherwise you'll need to tune for the extra air, especially if the cam is larger.
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
