tpi engine stalling out
Old Dec 29, 2012 | 03:40 PM
jjjosh's Avatar
Car: 92 B4C/91 Z28
Engine: 5.0/5.7
Transmission: 5 SPD/700R4
Axle/Gears: 3.42/3.23
HAVE AN 91 L98 52,000 MILES RECENTLY REPLACE HEATER CORE AT LOCAL SHOPP GOT IT BACK RAN FINE FOR A FEW DAYS AND NOTICED A SLUGISH KINDA FEEL WHEN I GAVE A LIL GAS TO BACK OUT THE GARAGE ALMOST KILLED THE ENGINE BOUT IT DIDNT DIE RIDING DOWN THE ROAD I FEEL A SOME LIKE JERKYNESS IN THE CAR... ALSO MY CRUISE CONTROL ISNT WORKING ANYMORE HAD NONE OF THESE PROBLEMS UNTIL IT GOES TO SHOP,,,FOUND THE FPR VACUM LINE DISCONNECTED AND VACUM LINE FROM THE TB TO THE REAR OF PLENIUM ,,, IT HAD AN INLINE CONNECTOR 2 INCHES FROM THE TB AND IT JUST HAD A PIN HOLE IN IT, CHANGED THAT OUT SLUGISH PROBLEM GOT BETER,, STILL THERE AND NO CRUISE CONTROL.. MY HEAT VENT STAY ON DEFROST NO MATTER WHERE I SIDE THE SELCTOR AND EVERY THING WORKS ON THE AC SIDE ,,, TURN HEATT ON AND THE SLUGISH PROBLEM IS WORSE..
Old Dec 29, 2012 | 05:35 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: tpi engine stalling out
take a look at the vacuum lines on the passenger side of the plenum. One goes to fuel pressure regulator ,another to the map sensor, and the other should be vacuum for your heater.
Old Dec 30, 2012 | 10:17 AM
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
Follow the vacuum line from the cruise control servo. It should lead to a one way check valve. Make sure all vacuum lines are connected to it. There should be 3 lines if I remember right connecting all of those should fix your vent problem and the cruise control problem
Old Dec 30, 2012 | 11:09 AM
ninetyone's Avatar
Axle/Gears: 3:42
without the vent vacuum line connected. Your system will be in default mode and constantly blow air out of the defroster.
Old Dec 30, 2012 | 07:08 PM
HighPressure's Avatar
Car: Pontiac Firebird ´87
Engine: L69 305
Hi guys..
I unmounted the quadrajet and egr.
Seems that i messed up the lines too. Has someone a diagram wich line has to go to what place?
I also hear a whistle when i turn on the heater, which is depending to how much I press the pedal (no matter if neutral or driving)
Would be great!
Old Dec 30, 2012 | 08:40 PM
jjjosh's Avatar
Car: 92 B4C/91 Z28
Engine: 5.0/5.7
so is the vent vacum line your referring to where is its location of it
Old Dec 30, 2012 | 11:58 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
sounds like the shop didnt put it back tg properly, thats why you should do everything yourself
Old Dec 31, 2012 | 01:47 PM
jjjosh's Avatar
Car: 92 B4C/91 Z28
Engine: 5.0/5.7
thanks for the help....the problem was under the dash,,,stterring colum was pushing up on vacum line thatsconnected to the same bracket as the brake light switch is mounted too,,,both where broken from the up pressure,, fixed and running great,,,, (brake light switch was also broken)
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
